Revit 2025 Project Browser - missing menu
christopherE8CSS
christopherE8CSS
Dear all,
In my newly installed R2025, I’m missing this additional toolbar.
How can I get it back, and do you know why it might have disappeared from the screen?
Thanks a lot in advance for your help.
Best regards,
Christopher
hmunsell
it should be there by default. Do you have all the latest patches loaded? I believe the latest is 25.4.30.30.
Howard Munsell
christopherE8CSS
Hi there,
I understand it should be there, but unfortunately, it isn’t. 😞
Could you please advise how I can check which is the latest patch installed on my system?
In this same office, this is the newest installation (new license) and it’s already causing us some headaches.
Thanks a lot for your prompt response!
hmunsell
click on the "?" and go down to "About Autodesk Revit 2025".
that will open a window. in the upper Right corner you'll see the full version number.
Howard Munsell
christopherE8CSS
Thanks a lot for this hint
A brand new licence has a number 25.0.2
So I will update it
Kind regards
hmunsell
no problem 😁. If the patch doesn't do it, let us know 👍
Howard Munsell
christopherE8CSS
Hi
We’ve encountered some issues with Revit installations in the office.
After noticing strange behavior in two instances of Revit, we decided to reinstall them and upgrade to the latest version — Revit 2025, as required by the project BEP.
Unfortunately, immediately after the reinstall, both versions stopped working entirely. We then performed a complete uninstall and clean installation of Revit 2025, but now the software won’t open at all.
It’s genuinely surprising how unstable Revit can be at times.
Kind regards,
