Revit 2025 Grid Lines visibility in 3D Views
jthaliburton
jthaliburton
Community Visitor
Community Visitor
I'm not sure if this is the correct place, but here goes...
In a Revit 2025 model the default 3D view shows grid lines. Any subsequent 3D views created, even duplicates of the default, do NOT show the grid lines.
Sometimes duplicated views will show solid gray lines without grid bubbles, but I can't find repeatable pattern to this behavior.
I have checked all project/view settings and they are the same between the default 3D view (grids showing) and duplicated 3D view (grids not showing).
Input appreciated.
Ryan_GormanKT36T
Did you check "Show Grids" in the Graphics Properties. Is everything checked?
jh8man1
New Member
New Member
Yes, I checked show grids. It did NOT resolve the issue.
TripleM-Dev.net
I think the 3D view needs to be cropped in order to let it show the grids.
