Revit 2024 will not Install (I tried this after issues Installing "How to Complete a Clean Uninstall of Revit products")
tturnerJBN46
tturnerJBN46
Revit 2024 will not Install. (I tried this after issues Installing "How to Complete a Clean Uninstall of Revit products"). Not finding any other solutions. The attached JPG shows what it says after almost finishing the Installation. Please advise.
Install Revit from your autodesk.manage.com. Not via Access.
tturnerJBN46
I did not use Access to try to install Revit 2024.
ennujozlagam
have you try to switch off all your anti virus program sometimes it is hindrance to installations?
tturnerJBN46
Yeah I did. It was the first thing on the Autodesk Clean Install list.
Did you do all the steps including #7 (Regedit)?  We didn't go there. We did all the steps above.  Perhaps you messed up the registry.  Do you have an Autodesk reseller?  If so, contact them directly.
tturnerJBN46
Yes. At first I skipped that step. But then when it did not work I included
that step also. Thank you, I will see what they can do and post a solution
when it works.
