REVIT 2024 running on parallels issue with Twinmotion
TVALLEJOZA
TVALLEJOZA
REVIT 2024 is running on parallels issue with Twinmotion
I have installed the latest version of REVIT 2024 and Twinmotion on an Apple M2 with parallels. When using the inbuilt plug for Twinmotion to transfer the 3D model to TM it opens TM but the REVIT Model doesn’t appear. Appreciate help. Thanks
a_julienPMZSA
Observer
Observer
Bonjour as tu trouvé la solution car je souhaite acheter un Mac M3Max, uniquement si je peux utiliser la 3D de twinmotion. car sauf erreur de ma part Enscape ne fonction pas. Merci pour ta réponse
English translation added by a moderator:
Hi, did you find the solution because I want to buy a Mac M3Max, but only if I can use twinmotion 3D, because unless I'm mistaken Enscape doesn't work. Thanks for your answer.
