hi everyone.
I'm having this problem only in version 2024. I insert a revit file to a Revit file (the host). Here I'm coping the link to create a number of floors. Now I use the export command to make a dwf file. Once I opened the dwf I can see only one floor which means only the file inserted, not the floors I copied. Important to mention that no such problem when I print to Pdf.
I did the same in Revit 2018 and Revit 2022 and there is no problem seeing all of the floors. I have used the same base templet for the trial for all the versions in order to understand the problem. It seems the problem is only in 2024. Please if someone can help me? THANKS ALOT. Sigal
hi,
Thanks for the lyrics 🙂 I love the song 🙂
I have tried the dwfx as well. The same problem. I have made many experiences before I arrived here 🙂 none of which helped me.
Finally I have informed the autodesk support. I think we are talking here about a BUG. So I'm waiting for their conclusions.
Thanks alot for trying to help me 🙂
did you used insert file rather than link revit file?
