Revit 2024 PC shut down and restart during Rendering
buildurdreamhome
buildurdreamhome
Hello everyone,
  • Please I need help my computer keep shutting down and restarting just as it's about to start to render, it also shut down sometime even if I am not working with Revit, my PC Specs MSI MPG Z590 Gaming Plus, inter i9-10850k, 32GB Ram, 1TB M.2 drive and AMD Radeon RX 6700 XT
  • My Email buildurdreamhome@gmail.com
Then this isn’t a revit issue
More than likely a hardware issue
Take your computer to a repair shop & have them troubleshoot if you don’t know how
HVAC-Novice
Agree with Ryan. check (or have someone check) cooling and quality of PSU. if it is a pre-built PC, or a cheap DIY, PSU and cooling usually are crap. check if all drivers are up to date from device manufacturer.
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
buildurdreamhome
Thanks bro, but I still done understand what is the problem I try rendering a scene in interior sun and artificial, with the render quality set to medium. The rendering start and all of a sudden the PC shutdown and restart, and when I change the render quality to draft, the scene renders successfully and PC does not shutdown
It's been explained on what to check
If you don’t know then take your computer to a repair shop & have them troubleshoot
It's not a revit issue
buildurdreamhome
PC freezes and crash especially when making changes in Revit materials
read entire thread again
