Revit 2024 Family
Revit 2024 Family
bloodlessuk
Revit 2024 Family
bloodlessuk
my revit 2024 family is missing ,i have downloaded the file but after extracting it does not move on to install window for some reason ,is there anything i am missing here ? can someone help me ...thanks
ennujozlagam
try to switch off all your anti virus program and try again and see if helps?
try to download here
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/2BQRb68xV4vUxhiNWfnv7k.html
syman2000
Since Revit 2022, you can access the family library by clicking on the Load Autodesk Family.
As for file download and installation, check and see if the Microsoft Security prevent you from installing.
HVAC-Novice
I don't know when it started, but my version has instructions on how to get content. they probably know this keeps disappearing. i have re-installed the oob families multiple times and kind of gave up.
I just use the cloud oob families. they have a nicer search anyway and don't disappear.
Since autodesk is not fixing the "disappearing" installed oob families, I assume they will give that up and focus on the cloud.
Revit Version: R2026.4
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
@HVAC-Novice : Have you downloaded the content library? If so, you are in the wrong folder. Backup and open the content folder - whatever its name is.
HVAC-Novice
this is the " imperial Library" folder.
I had successfully followed instructions multiple times to re-instate to oob families. The problem is, after a while (maybe after updates?), it disappears again. I just don't bother anymore and use the cloud oob families.
The cloud families seem to be the same ones. they can just get rid of that local copy of oob families to make it less confusing.
