Revit 2023 "Encounters serious error" when trying to change a Design Option to Primary
matthewJVP4M
Message 1 of 9
matthewJVP4M
Title says it all. Revit build 23.0.10.18; model is a Workshared Cloud Model. When trying to make a Design Option a Primary Pption, I get this error message. I can select "no" and continue working in the model, but still cannot make a Design Option a Primary Option. As such, I don't know what will happen when I then Accept Primary. Anyone else having this issue?
Replies (8)
Message 2 of 9
Could it be a permissions issue?
Message 3 of 9
matthewJVP4M
I doubt it. I've never encountered permissions issues before, so I don't know what it would even look like if it was.
Message 4 of 9
I'm talking about Workset permissions.
Message 5 of 9
matthewJVP4M
All elements in the option are on the same Workset, which is also the main workset we are using for the model, so I don't know what issues that could cause.
Message 6 of 9
maybe an issue like you're having? Dunno.  Just running it up the flagpole.
Message 7 of 9
Go through Warnings under Manage tab and try to resolve as many as you can, particularly the ones related to design options.
Message 8 of 9
What about CUT/PASTE from DO to Main? That work? It's a valid approach.
Move Elements from One Design Option to Another | Revit 2016 | Autodesk Knowledge Network
Message 9 of 9
matthewJVP4M
It likely would, and that was the path I was saving for last. I was just looking to see if anyone else had any issues with Making Primary options with R23.
