Revit 2023 not located in add remove programs Windows 11
lr-PAYNE
lr-PAYNE
Trying to complete a re install of Revit 2023 as It originaly didnt install any templates and I cant seem to uninstall at all.
add removes programs in windows 11 has all the things associated with Revit 2023 but Revit 2023 is not listed, so I cant uninstall. FYI I can still open and use Revit 2023.
Anyone have a solution?
DarrenP
you can get the content from here: https://knowledge.autodesk.com/support/revit/troubleshooting/caas/downloads/content/autodesk-revit-2...
DarrenP
David_Knight
it shows up for me, and I am running windows 11.  Mine was a fresh install of windows 11, not a migration.  If you migrated, there may be a reason its missing.
lgilmore
I am having the same issue.  Add-ins are missing from Revit 2023 and wanted to uninstall and reinstall, but the program is not showing up in the control panel add / remove programs list.
Simon_Weel
The content, like templates, is no longer included in the installation. You have to install them separately. So no need to re-install Revit. Not showing up under programs could be a Windows 11 thing? Not sure. You could try Bulk Crap Uninstaller, as it lists just about anything installed.
