Revit 2023 custom install to a particular update version
mo
Message 1 of 11
mo
Hi, I just want to know if its possible to update to a particular version? The custom installl only provides 2 options. A very early update and the current update. Nothing in between.
Replies (10)
Message 2 of 11
ennujozlagam
you can update from here?
Message 3 of 11
mo
No that did not work for me. It only provides us with the latest update where the update i wanted was released May 2023. Either case i managed to get around it. I found i still had that old update install folder in my C: drive so I installed from custom install the early release of 2023 than applied the desired update.
But for others who may be trying to install an older update, I would not know where you would source these older install files if you had to.
Message 4 of 11
ennujozlagam
if you are under autodesk subscription then you need to check in your autodesk account?
Message 5 of 11
mo
Yes I have tried that. I went to my Autodesk account then went custom install but it only lets me download a full install of 2 version of Revit 2023. The first update and last update. Nothing in between.
Message 6 of 11
ennujozlagam
what do you mean nothing happen?
Message 7 of 11
mo
What I am saying is that in the custom install option there is no other update to choose from besides the very first update and the current latest update.
Message 8 of 11
ennujozlagam
these are only updates i can see?
Message 9 of 11
mo
Yes as you can see right at the top it only shows the current update to download. None of the previous one. THe rest are just the addons to revit 2023
Message 10 of 11
ennujozlagam
another way contact autodesk?
https://www.autodesk.com/support/contact-support
Message 11 of 11
mo
Yes that may be the only other way as I mentioned above i was lucky enough to find the update saved in the default install folder so i could install that particular update. If I hadnt i would probably tried to contact Autodesk to see if they can provide a link to them unluess someon knows of another way.
