Revit 2023 Crash
Revit 2023 Crash
kennygreenwood
Observer Observer
Revit 2023 Crash
kennygreenwood
Observer
Observer
Hello!
When I open a project in my revit, i get this error:
Aplicativo: Revit.exe
Erro: C++ EH exception - code e06d7363 (first/second chance not available)
Nome do módulo com erro fatal: mscorlib.dll
Endereço da exceção: 0x00007fff9644fabc
Código da exceção: e06d7363
Sinalizadores da exceção: 80
Parâmetros da exceção: 19930520, e88eef51e8, 7fff1838b2b0, 7fff17640000
Anyone can help?
Tipo da exceção gerenciada: System.Runtime.InteropServices.SEHException
Endereço da exceção gerenciado: 0x0000020eb49343d0
esk0r
Could be a few things but first of all, check that you have all updates installed for that version of Revit.
Follow suggestions from this post to troubleshoot further: "Revit has stopped working" when launching Revit - Event Log shows: Faulting module path: C:\WINDOWS...
Rene Pellicer Garcia
TripleM-Dev.net
Hi @kennygreenwood,
See post: https://forums.autodesk.com/t5/revit-architecture-forum/revit-2023-crashes-when-using-visibility-gra...
Error doesn't happen on project open but does have same error, maybe related.
See if the solution below helps, else subscribe or mention the error in that post?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Crash-when-editing...
kennygreenwood
Observer
Observer
Hello, already saw this topic and followed the steps, but no solution.
Afaik its a C++ error but i couldnot find any solution =/
kennygreenwood
Observer
Observer
I've reinstalled revit, net.framework and also repaired the O.S.
I think i will format the PC.
