Revit 2022 Text notes moving when print to pdf
schoof.jesus
schoof.jesus
Every time when I print to pdf the text notes move from their position and overlap. I tried to fix it in the print configuration but the only change that i achived was to move it in diferent directions. This only hapen whit the text notes that are rotated in vertical.
ennujozlagam
try another pdf printer like BULLZIP and see if helps. thanks
Revit 2022? Use the native Export to PDF.
