Revit 2022 load as group
etick
etick
I am using Revit 2022
22.1.21.13
20220123_1515(x64)
2022.1.2
In this version the function load as group is broken, it does not work anymore.
When i use this option in this version, the message states Unable to load file "IND_02_H_mv_lw" as a group.
syman2000
Do you have objects hosted on surface outside the group? If you copy and paste the group, will it still works?
etick
There are no objects outside the group.
Copy and paste works. That is if you open the group file as a project.
etick
Copy and paste within the same document works, however between different documents not.
I could find that one off the families is causing problems, this one does not copy and paste.
Problem is that Revit does not give any clue why not 😞
