Revit 2022 Library
Revit 2022 Library
Revit 2022 Library
Hi everyone,
I am a student and downloaded Revit 2022 for school, but nothing my professor was using was on my version. So I went and downloaded the Revit 2022 content from here:
I have more options now, but still not the ones my professor was using. An example of a wall type I'm looking for is "Basic Wall Exterior - Brick on CMU". All the wall types on my version are listed like this: "Wall-Ext_102Bwk-75Ins-100LBlk-12P". The same thing goes for windows and doors.
Any help would be greatly appreciated!
Thanks!
Start your project from an Architectural Project template then you would have the OOTB wall types.  If you want to continue with the project you have, then Transfer Project Standards from the above template.
Walls are System Families - not loadable Families like the ones found in the Content Library. Chances are the Walls Types your are looking for are defined in the Project Template (RTE).  "Basic Wall Exterior - Brick on CMU" is a Wall Type in the Default.rte.
