Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Revit 2022 - IF/Boolean statements
mike_key
mike_key
I have a sink family that has two faucet options: Standard as Wrist Blades, or an Electric Sensor faucet. I have two visibility parameters that will hide one faucet or the other just fine. However, Once I show the Sensor faucet, I need to add a note in my type comments column of my schedule. Revit does not like ChatGPT's formula...
All help would be appreciated.
RDAOU
@mike_key
Try this
if(Sensor Faucet, "K.E.C. TO PROVIDE FISHER #FAFB-HW-SBSE ELECTRONIC SENSOR SPLASH MOUNTED FAUCET", "")
Why ChatGPT formula did not work... A boolean in revit should either resualt a true or a false .... 1 & 0would work in other programing languages  but in revit they are not a valied arguement. In revit you need to use arguemens such as
  • 2>1  means True
  • 2<1 means False
  • 1=1 means True
  • 1=0 means False
Or simply use
for True:     = Sensor Faucet
for False:    = not(Sensor Faucet)
mike_key
Thank you so much...
