REVIT 2022 - Exporting Schedules in text format - Encoding
William_Gonzales_Sanchez
Hi all,
When exporting schedules in text format, is there a way to set the encoding?
We have an application that reads those text files and stores the schedules fields in a relational database, it worked fine with REVIT 2019, recently we have migrated to 2022 and the application reads strange characters, after some research, I realized it is because the encoding, it needs to be set to ANSI.
William Gonzales
denis_borodin
I doubt you can change the encoding in Revit, but it is easy to use Notepad++ to change
Denis Borodin, BIM Manager. LinkedIn
