Weekly New Knowledge Articles by Support team | Apr 18 - 28th, 2023
0 ANTWORTEN 0
Nachricht 1 von 1
lim.wendy
97 Aufrufe, 0 Antworten
Our Revit support team has created knowledge articles for you to address the issue on your own. Several incidents have been reported, so be sure to review them for potential workarounds.
Published Date
Summary
Knowledge Article
Incident Logged
28-Apr-23
"Changing linked positions is disabled when collaborating on Autodesk Docs"  when trying to acquire coordinates during Revit Cloud Worksharing.
"Changing linked positions is disabled when collaborating on Autodesk Docs"  when trying to acquire ...
No
28-Apr-23
CAD file inserted into a model is only visible in one view in Revit.
CAD link present in a view is not visible in other views in Revit
No
28-Apr-23
How can Docs Coordination Model Views be used for IFC linking in Revit Cloud Worksharing files?
Linking IFC files as Docs Coordination Model Views in Revit 2024
No
28-Apr-23
Section name is not shown in the section head in Revit.
Section head does not show section names in Revit
No
27-Apr-23
Unable to create floor plans or ceiling plans based on the levels from the linked model in Revit.
Cannot create floor plans or ceiling plans based on the levels from the linked model in Revit
No
27-Apr-23
How to adjust cable tray with a sloping framing or ceilings in Revit?
How to align cable tray into a sloping framing or ceilings in Revit
No
26-Apr-23
Incorrect material pattern alignment for shaped edited floors in Revit.
Yes
26-Apr-23
After install Spacemaker Addin Icons are not visible in Revit 2023
No
26-Apr-23
The label opacity in title blocks families is incorrect when exporting to PDF from Revit.
Yes
25-Apr-23
Users reported that bending angles in rebar schedules are not displayed when using "Show names" option in Revit.
Angles in rebar schedules are not displayed in Revit.
Yes
25-Apr-23
Electrical fixture symbols are not matching with the Revit model when exported as DWG from Revit
Yes
25-Apr-23
When opening Revit models on certain systems, the fonts display differently.
Font changed when Revit model opened on one system
No
25-Apr-23
Users reported that after reopening a project in Revit, spot elevation tags from a specific view are losing the correct position. After selecting them the display is as expected again.
Incorrect location of spot elevation tags in specific view after reopening the project in Revit
Yes
25-Apr-23
Pipes modelled and exported as IFC from Revit 2023 are not visible in BIMVISION viewer
Pipes modelled and exported from Revit 2023 are not visible in BIMVISION viewer
No
25-Apr-23
"Enter a value or a formula starting with "="." upon entering value in forces under Area Load in the Analyze tab in Revit
"Enter a value or a formula starting with "="." upon entering value in forces under Area Load in the...
Yes
25-Apr-23
Last member of group instance was excluded (deleted), removed, or moved to the project.  when creating a group in Revit
Last member of group instance was excluded (deleted), removed, or moved to the project.  when creati...
No
21-Apr-23
"The requested file cannot be overwritten due to being a different type such as a published model" when publishing coordinates to a linked file in Revit.
"The requested file cannot be overwritten due to being a different type such as a published model" w...
No
21-Apr-23
Users reported high CPU usage when running Revit offline.
High CPU usage when running Revit offline
Yes
21-Apr-23
Users reported that the point cloud (RCP) linked by shared coordinates is slightly shifted in Revit 2023.
Point cloud linked by shared coordinates is slightly shifted in Revit 2023
Yes
21-Apr-23
Users reported that rooms are not exported to IFC from Revit.
Rooms not exported to IFC file from Revit
Yes
21-Apr-23
Line spacing varies for different fonts in labels in Revit.
Row spacing is not the same for all fonts in labels in Revit
No
21-Apr-23
RTL text spaces are incorrect exporting to PDF/DWF from Revit
Yes
21-Apr-23
The Roombook command cannot be added to the Quick Access Toolbar in Revit
Yes
20-Apr-23
Cannot rotate a family instance using a transformation matrix in one run in Dynamo for Revit.
Cannot apply transformation matrix in one run in Dynamo for Revit
No
20-Apr-23
When upgrading a model, Titleblock revision schedule is corrupted and the upgrade process fails in Revit.
Titleblock revisions schedule is corrupted and fail to upgrade a model in Revit
Yes
20-Apr-23
Unable to select or greyed out RevitDBLink icon in Revit 2024
No
18-Apr-23
DWG Exported from Revit doesn't link into the same location in Revit.
DWG Export doesn't link into the same location in Revit
No
18-Apr-23
Users reported that parameter with unit "mass per unit length" exported with wrong value to IFC from Revit
Parameter with unit "mass per unit length" exported with wrong value to IFC from Revit
Yes
18-Apr-23
Room tags from CAD link are not visible after applying color scheme for rooms in Revit.
Room descriptions from DWG file are not visible after applying color scheme for rooms in Revit
No
18-Apr-23
Lack of Structural Plan View in Revit LT in dropdown menu
No
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
0 ANTWORTEN 0
