Revit 2022 export to PDF sheet name
Gerben_TVDB
Gerben_TVDB
When trying to Export several (or single) sheets to PDF using the sheet number, Revit gives an error saying 'The naming rule can not be applied to the selected views or sheets'.
Is there a way to let Revit write PDF-files including the sheet number?
michael.coviello
Autodesk Support
Autodesk Support
@Gerben_TVDB
When you add the Sheet Number and Sheet Name,  These two should be added from Parameter Type = Sheets in the Setup Naming Rules Dialog box.
Although Sheet Number/Name exist in the Views Parameter type, using them would give this error.
Here is a another post on this topic as well.
https://forums.autodesk.com/t5/revit-api-forum/2022-pdf-exporter-cant-use-quot-sheet-number-quot-par...
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-ECB1C2B4-AA62-4836-892C-871DA9F7927B
Please click Accept if this solves the problem.
Michael C
Technical Support Specialist
What's New in Revit 2023 | Autodesk University | Revit Blog
luisPDAN6
It is a shame. We use the Docuflow app to generate PDFs and it really works well with filenames, detection of sizes, and multiple export at the same operation.
Yes.
michael.coviello
Autodesk Support
Autodesk Support
Hello @Gerben_TVDB
I'm checking in to ask if certain posts have helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Michael C
Gerben_TVDB
Thanks Michael!
