Revit 2022 Deployment Error
mrensing
mrensing
Trying to use the new deployment tool, and I have run into an error.  I think it has something to do with the Extensions. I haven't had a chance to track down which one/ones are causing this error, but the only way i have been successul with it is by creating a deployment with no extensions selected. The log file shows the following: [0x00002f50] [error] [0x000016b0] [228] Download error: -113
It may be a similiar issue to this: https://forums.autodesk.com/t5/installation-licensing/building-multiuser-revit-2021-1-deplyment-from... that has resurfaced in 2022.
I'm having same issue
huotger
Sorry you encountered this error.  We believe that this issue has been resolved in the past hour, can you try recreating your deployment configuration from Accounts?
Gerry Huot
SQA Manager
mrensing
Thank you.  That fixed it.
mrensing
I needed to make an adjustment to the deployment.  It looks like the error is back. I tried multiple times Friday, and then again Monday.  Can you please fix this issue again?
david.smith8GZ68
Hi All, seem to be getting this error now -113 when the deployment tool is downloading the package, any ideas on how to resolve this?
Rusty_Gesner
And it is happening again with Revit 2022.1.3
