revision management in titleblock
3 ANTWORTEN 3
Nachricht 1 von 4
philsogood
231 Aufrufe, 3 Antworten
hi,
i'm xandering hox i can hide a revision in a title block
i'm working on a selling project and the number of historic of revision isn't important
id' like to see only one revision, the last one, how can i do this?
thanks for your tips
Phil
[url=https://goopics.net/i/m7aGE][img]https://i.goopics.net/m7aGE.png[/img][/url]https://goopics.net...
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: philsogood
You need to shown the Revision 1 Cloud in the View and then HIDE it. This will activate Revision 1 so that you can uncheck it.
Re: Obsoleted revisions unavoidably visible? - Autodesk Community - Revit Products
Nachricht 3 von 4
philsogood
als Antwort auf: barthbradley
hi Barth and thanks for your help
I need to see the revision B but not the A and i want to see the B on the revision....
if I unchecked the first revision, the revision in the title block will be A whereas the draft has ever been sent one time so I need to show B, not A...
Other question : what does the box "issued" is used for in the sheet revision windows?
thanks
Phil
Nachricht 4 von 4
Does the link I posted describe your issue? If so, I described the solution in that thread. If not, I'm unclear about your issue.  Please elaborate and include screenshots of your Revision settings.
Regarding Issues: here's a comprehensive explanation:
Issue a Revision | Revit Products 2016 | Autodesk Knowledge Network
