The question is:
With Revit 2017.2.3/2018.3/2019.2, I can change the clipped project base point coordinates. How can I do the same with Revit 2020.2/2021?
See explanations below:
Comments:
* Revit version used: Revit 2019.2
* I use a Revit linked file to show the origin of the file.
* In France, we use the Lambert coordinate system (see here)
Example:
In this case, the circle center point coordinates in the site plane dwg file correspond to the future axis intersection point coordinates of the building in the Revit file.
The circle center point coordinates are: X:1579300, Y:2261500
[cid:
[email protected]][cid:
[email protected]]
Figure 1: put the building on the good place with coordinates on the site plan
In Revit 2017.2.3/2018.3/2019.2, I fill in the fields of the clipped project base point coordinates (see figure 3 below) with the circle center point coordinates that was drawn before in the site plane dwg file (see figure 1 above):
X:1579300 => E/W: 1579300 (E/O in French)
Y:2261500 => N/S: 2261500
[Une image contenant texte Description g?n?r?e automatiquement]
Figure 2: Origin point at the same place of the project base point before the change of coordinates
Figure 3: building project base point coordinates fill in with the site plan coordinates (origin point and project base point always have the same coordinates because clipped)
To check if it works, I linked the dwg site plane file into the Revit file (see images 4 and 5 below)
Figure 4: link the dwg file in the Revit file
[cid:
[email protected]]
Figure 5: Revit file with the clipped project base point coordinates which correspond to the origin coordinates
It is an easy way to get the coordinates of the origin point.
But now, with Revit 2020.2/2021, I do not know how to do the same stuff.
The only possibility I imagine with Revit 2020.2/2021 is to "physically" move the clipped survey point, but that is not practical.
With Revit, moving an element several million meters is a fairly complex task.
Link to files used:
https://we.tl/t-foVVmeMVORBest regards
Samuel Locus
BIM Manager
[email protected]+ 33 6 37 50 30 29
[VIGUIER]
VIGUIER architecture urbanisme paysage
16 rue du Champ de l'Alouette
75013 Paris, France
+33 1 44 08 62 00
www.viguier.com[facebook][twitter] [instagram][linkedin]
