Revit 2021 material library missing
joshlim0918
Message 1 of 11
joshlim0918
Good day ! I would like to ask how to install or load the missing materials on Revit 2021? It says that one or more texture files cannot be found and there is also an orange exclamation mark beside the materials.Capture.PNG
Replies (10)
Message 2 of 11
That little triangular orange symbol just means that the Material is using a Legacy Appearance Asset as opposed to the newer PBR Appearance Asset.  All's good.
...and to see what textures are missing, go to the Appearance Tab of the specific Material. You'll probably see this:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/E...
Message 3 of 11
ennujozlagam
you can try to refer to this ARTICLE and see if helps. thanks
Message 4 of 11
joshlim0918
Message 5 of 11
@joshlim0918 wrote:
I'm confused all of the mats are not flat images.
me too. it was better in the olden days.
Message 6 of 11
joshlim0918
Should I just use an older version of Revit or is there a solution to this?
Message 7 of 11
What kind of solution are you seeking?
Message 8 of 11
joshlim0918
Like if can still use the legacy textures?
Message 9 of 11
What's stopping you, @joshlim0918?  Nothing should be preventing you from using Legacy Materials.  What's going on at your end?
Message 10 of 11
I think you are just a bit confused by the UI. We were all confused when Revit introduced those ominous-looking, triangular-shaped markers on the Material swatches.
Message 11 of 11
joshlim0918
How do I find the missing texture files?
