Revit 2021 issues
Revit 2021 issues
hughecchapman
Revit 2021 issues
hughecchapman
I have a project which needs to stay in R2021 to ensure compatibility with the rest of the design team.
I currently have two issues with R2021 I can't work out how to resolve:
1) The properties tab is not visible. I've tried everything suggested here except re-installing Revit 2021 which seems to be the 'nuclear option'.
2) Revit won't let me link dwgs. I get this error message
I close this message (twice) and then get this error -
Can anyone help me with these issues?
Many thanks
SteveKStafford
Regarding the properties palette, check your graphic card/Driver compatibility in the Options dialog. What does Revit "think" of the graphics card/driver? Are you using a Display Scale greater than 100% in the operating system?
When you attempt to link a DWG are you using the option to specify the Units instead of using the Auto option. Does this happen with any DWG file or just specific one(s)?
Steve Stafford
hmunsell
From what I understand of the licensing, you have another Year and a half . I believe you'll loose 2021 when 2026 comes out? maybe its 2027...
Well @SteveKStafford took most of my questions 😂
Only other thing I'd ask is are you trying to link directly from dropbox? or are you copying the DWG's to your project first?
Howard Munsell
