Revit 2020- Schedules on Sheets fail to update
MattKincaid
MattKincaid
We've noticed that when you place a Schedule on a Sheet, it doesn't always update when a relevant model change is made.  The Schedule View itself does update.  But the schedule on the Sheet still contains the old model information.
Deleting the schedule from the Sheet, and adding back manually seems to fix the problem.  But is there a better fix (from Autodesk) coming soon?  Seems this has been an issue for some time.
Thanks!
HVAC-Novice
I came across that problem as well. It will eventually update on its won. or after you re-open the sheet or the project. No need to delete and re-insert the schedule from the sheet.
It goes against the REvise InsTantly idea and seems to be a (minor) bug.
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
MattKincaid
Yes, I've noticed it does seem to update eventually.  Restarting Revit works, consistently.  Or, sometimes adjusting a schedule column width slightly will force an update.   But that, of course, requires noticing the problem in the first place, which isn't always obvious.
