@prichmond wrote:
This good information but I need to provide our customers with something they can use to cut the floor in their projects. I have no control over the floor family or anything in the project beyond my content.
That is why I was asking if I am doing something wrong or is there a best practice I can point to for customers who do not know enough about Revit.
Does this make sense?
Phill
The most flexible approach when you don't have control of the host is using a face based or work plane based family.
- Face based: add a void in the family and cut the solid hos with it so that when your place it in the project it will cut applicable host.
- Work plane based: add a void in the family and set the family to cut with void when loaded. After place the family in the project you can use Cut Geometry to cut what needs to be cut.
Between the two above, work plane is more flexible because you can cut multiple elements with your family (think there are a finish floor and a structural floor below it).
