Hi, the SLT Exporter add-in isn't available in Revit 2019 nor can I find it under the download section in my Autodesk account? Is it available in 2019 and if so where can I find it?
If not, do you know when it will be available and is there any kind of work around I can use till then?
Solved by Viveka_CD. Go to Solution.
Can not check it at the moment. I expect it is just not available (yet). It should appear in the Autodesk desktop app when it becomes available
(The 2018 version was released last year on 28th July. So it might be a while)
Louis
Please mention Revit version, especially when uploading Revit files.
The accounts page lists the STL Exporter for Revit 2018. See image below:
I'll check back with the team for information regarding STL exporter for Revit 2019.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Initial testing is going on. I'll let you know as soon as we have an update.
Feel free to ping me @Viveka_CD and check back in a couple of months.
Viveka CD
I've marked the solution to benefit the community. We can continue the conversation once we have Revit 2019 STL available for download. Current status is that a dedicated team is working on this resource.
Viveka CD
Hi @Anonymous
Yes, it is available for download via the Autodesk Desktop App and Autodesk Accounts.
Please see this thread for more information.
Please select the Accept as Solution button if my post solves your issue or answers your question. Likes welcome!
Viveka CD
Encontrei o exportador para STL do Revit 2019, sem a necessidade de baixar direto pelo sistema da Autodesk. Segue o link https://github.com/Autodesk/revit-stl-extension/releases
