Revit 2019 - Stair with Ramp
I've just created this stair with built in ramp but can't quite it to look totally right.  The flat surfaces are floors but how do you get the edge which is actually a riser I suppose, be in the same material as the top surface?  Also, some of the steps stick up above the ramp which would be a tripping hazard in real life.  Maybe its the way I created it as steps and the ramp as a floor with a slope to suit?
Also, can anyone recommend a really could external flag material for the finish.  Just put on the normal flag from the library but its pink and looks rubbish ( the flags are really small in size )
Ta.
Are you wanting to wrap the ends with the stone. Use the Paint tool to apply the material to those edges.
Ta.
If you are talking about these parts sticking up then they are not a Revit problem, you need to alter the design to fix them, either re-calculate the layout so the elevations matching up at these locations, or trim the steps to match the adjacent slope, or provide toe-guard / handrail / bollard there...
Hi, Thanks, sorted the sticky up bits and daft me forgot the simple paint solution for the edges!!  Now, I have noticed a weird error on the group of 6 steps to the right hand side.  If you look the image pattern is twisted.  The stairs are all under the same name so I don't know why this is happening.  Can anyone help explain it please?
Thanks.
