Revit 2019 - Walls Won't Join Properly
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
4280 Aufrufe, 4 Antworten
As the title says, I'm working in Revit 2019. I have a pair of walls that I can't get to join to each other properly. They are the same wall type; they are on the same level with no base offset; wall joining is allowed (they are technically joined, but continue to show a cut line between them); there is no phasing in the project, so that isn't interfering with anything; I've tried pulling each wall back and dragging the control points back together; I've tried changing the wall join style; I've tried pulling the walls back and using trim/extend; I've tried using modify>geometry>join. I'm hoping one of you geniuses can tell me what I'm doing wrong.
Tags (3)
4 ANTWORTEN 4
Nachricht 2 von 5
cbcarch
als Antwort auf: Anonymous
Are either of them attached to the roof?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 5
als Antwort auf: cbcarch
They are each attached to the same 2 roofs - one internal that ends at the interior core boundary of the wall (which I'm using as a ceiling b/c I need to cut it with a roof-based family), and one that is the actual exterior roof. These are 2 of the 4 exterior walls, all 4 of which are attached to the same 2 roofs in the same way, and this is the only corner giving me this issue.
Nachricht 4 von 5
cbcarch
Attaching can sometimes cause wall join problems. Try Detaching and see if they clean up. If so, maybe use a reference plane to attach the walls to, or just use an offset from a Level or an unconnected height instead. Odd that the other two walls clean up.
Cliff B. Collins
Nachricht 5 von 5
Aw geez Rick, I made one of the walls structural! Thanks for the suggestions.
