Revit 2019 Material Library not working
Message 1 of 47
Dear Team,
I had installed 2018 Revit & material library was not working & uninstalled it.
Now i have installed 2019 Revit, but material library is still not working.
Kindly help.
Thanks in Advance
Kavitha
Replies (46)
Message 2 of 47
Not working how? The material manager window does not open?
Message 3 of 47
It Opens but the complete materials is not visible.
Attaching the image for reference.
Message 4 of 47
Viveka_CD
Hi @Anonymous
Did you try a repair of Revit and let me know if that helps?
Message 5 of 47
Hi
I did repair, then also its not working 😞
Message 6 of 47
Looks like it's fully opened in your screenshot. It doesn't appear to be missing anything. What do you think it is missing?
...FWIW, the yellow icons represent legacy materials.
Message 7 of 47
ennujozlagam
hello, try to update your graphics card driver to the latest and see if helps. thanks
Message 8 of 47
Hi
Material dialog box opens but all the materials doesn't appear & when i apply the showing material to a object, it doesn't get applied, the object  remains the same as earlier.
Message 9 of 47
Hi
I did try updating graphic card also & even tried disabling the graphic card & checked, its still the same.
Message 10 of 47
Viveka_CD
Hi @Anonymous
Can you share your journal file to investigate further?
See HERE for information on locating your journal file.
Di you recently install and recent updates for windows?
Message 11 of 47
Is it possible that the material is applied, but that your View Detail Level and/or View Visual Style settings aren't allowing you to see them? Or,  perhaps, the Material itself doesn't have a unique Graphic Appearance (i.e. Shading Color, etc.)?
...how are you applying Materials to elements?
Message 12 of 47
Have attached the journal folder.
Message 13 of 47
Hi
I did check the view style, but that's not the issue.
Have attached a image.
Message 14 of 47
I guarantee you that the issue you are having has nothing to do with the Material Library not working.  Sounds like what you saying, is that you are trying to apply a material to an element, but don't know how.  What is the element? Can you provide information about the element's Type Properties.
Message 15 of 47
Sir, sorry but i have been learning this software from an institute & i am well aware on how to apply materials to elements. When the institute people also dint know the solution for this, i have raised my concern here. When i meant Material Library, i am referring to complete materials which comes default with the software, which is not shown in the material browser. Only few materials option is there, which also shows a yellow mark & also when i apply the material, it is not applying to elements. As i mentioned in my earlier reply, RGB Value is not changing for the entire color options in graphics except for Shading.
The elements i am trying to apply material is basic wall & basic floor
Message 16 of 47
Viveka_CD
Hi @Anonymous
I am unable to open your journal file - can you repost and try sending again?
Does this error happen in particular models or most models?
Can confirm if Revit 2019 installation on your machine meets requirements as recommended by Autodesk?
See system requirements HERE and hardware tools HERE
Message 17 of 47
This is happening to all the files, i tried creating a new file, the same problem in that also.
Message 18 of 47
Were you able to resolve this? I am having the same issue!! I'm
Going to have to go back to 2018 if I can't get it sorted
Message 19 of 47
Viveka_CD
Hi @Anonymous
As mentioned above, could you please confirm if Revit 2019 installation on your machine meets requirements as recommended by Autodesk?
Message 20 of 47
Viveka_CD
Hi @Anonymous
I'm checking back on this issue.
If you still facing the issue - Please send us your files for further diagnosis. Please see Revit - Collecting and sending diagnostic data to Autodesk Technical Support
Let me know and I can create a private upload folder for you.
