Callout Tag Head Modification
17 ANTWORTEN 17
GELÖST
Nachricht 1 von 18
5165 Aufrufe, 17 Antworten
I am trying to customize a callout tag and omit the bubble head portion. In place of the bubble callout head i would like to place a leader.  (see attached WORD file w/ screen shots).  I tried duplicating the callout tag type but its not allowing me to just make one callout tag with no head.  Can anyone help me?
17 ANTWORTEN 17
Nachricht 2 von 18
als Antwort auf: Anonymous
No head? Just a leader and arrow?
Nachricht 3 von 18
als Antwort auf: barthbradley
@barthbradley
Well i want to get rid of the bubble portion and if possible the leader coming out of the callout.  Yes just to have a leader with arrow coming out from the callout box.
Nachricht 4 von 18
Make the label read a parameter that will never have a value, or associate a visibility TYPE parameter to it and have it turned off by default.
Nachricht 5 von 18
Sahay_R
Save a copy of the OOTB Callout Head family. Switch out the circle for an arrowhead. Move the label to a new appropriate position (if you need it at all, if not, delete it. When you place the callout, it will automatically create a leader (not necessarily curved to the new Callout Head arrow. Let me know how it works.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 6 von 18
Why bother with callouts, just use a generic annotation symbol for the callout so you can add a leader freely.
Nachricht 7 von 18
Corsten.Au
Corsten
Building Designer
Nachricht 8 von 18
@barthbradley
Seems like a way to go about it, but how would i do that?  I like the visibility idea to turn on and off, and if that could work on just this instance and not update all callouts in the project.
Nachricht 9 von 18
Sahay_R
@Anonymous - you would need to create types in the tag family, and then callout view types in the project.
Rina Sahay
Nachricht 10 von 18
als Antwort auf: ToanDN
Yes, that i could do as well.  In fact that is what i ended up doing for now.  However ive come across this before and would like to find a way to be able to manipulate that family.  Can system families be duplicated and saved as?
Nachricht 11 von 18
als Antwort auf: Corsten.Au
@Corsten.Au,
This is the system family break down for callouts.  I guess looks like i would get rid of or hide visibility of the right most info. (which shows up in the bubble).
Nachricht 12 von 18
als Antwort auf: Sahay_R
Thanks @Sahay_R
I went into Edit Type and duplicated the tag, ( i think), and still had the family not working.  Could you p;ease elaborate the process?
Nachricht 13 von 18
@Anonymous wrote:
@barthbradley
Open your Callout Head family that is assign to the Tag and associate the label's Visibility parameter to an ON/OFF Type Parameter (created by you).  Create a new Family TYPE (e.g. "1/2" Invisible") with the default ON/OFF position unchecked; load it into your project and use that "Invisible" head Type in another Tag Type (Duplicate/Rename method)  for use in those instances where you you don't want any label shown.
Nachricht 14 von 18
Thank you @barthbradley :leicht_lächelndes_Gesicht: Im gonna give that a try.  Could be also a way to deal with the length of View Titles on a sheet!
Nachricht 15 von 18
How do you add a leader with arrowhead to the call-out even with the bubble turned off? For a better understanding, what is the arrow pointing to?
Nachricht 16 von 18
@ToanDN
I am pointing to a blown up portion of a plan.  I used a in house text style called "Leader" that has no text attached, so basically you just get a leader with a void text placeholder (with not text to the right or left of the leader).  That portion i would tuck or align into the call out tag box.
Nachricht 17 von 18
@Anonymous wrote:
@ToanDN
Since you are giving up on the bubble so you no longer need the call-out "lives", you could use a generic annotation family so that you can leader(s) more easily.
Nachricht 18 von 18
@ToanDN
That makes more sense i guess since the original way puts alot of limitations on the overwriting of the system family.  I did not know you could create a generic annotation family (DUH :/)  I will have to look into creating one then, as it does take all the work out of modifying the system family. Thank you!
