- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi All,
I'm having an issue with Revit 2019. Its currently fully patched after being re-installed. I'm currently using s Dell 5520 laptop with a company OS, and sadly McAfee encryption and AV.
The issue I face is that the program freezes, often in mid command for no reason I can see or trace, every 5 minutes or so, I've not actually timed this, maybe I should. I do have Revit 2019 on a desktop machine which does not have the same issue so I know its a problem with the laptop. I don't know where to start looking for the cause as Ctrl-alt-del worked just fine as do other applications, Revit just seems to take a quick break, no other application shows the same behavior, only Revit.
Any help or guidance will be most gratefully received.
Roy
