Revit 2019 Export to NWC issues with coordination models
Message 1 of 23
I am unable to export my model to an nwc file after I have inserted a Navisworks coordination model into my project.
I am able to create the nwc file up until a coordination model is inserted.  After that I am no longer able to export to nwc.  I have tried unloading and even removing the coordination model, however the same error (below) keeps popping up.  Is there a workaround for this?  Anything I'm missing?
Replies (22)
Message 21 of 23
Viveka_CD
Hi @zpruitt.Harper
Can you share a playable journal and a screencast to investigate further?
Message 22 of 23
Is there any update here?
I have the same problem: I imported some Coordination Models (nwc) into Revit and I cannot export any other view to NWC.
I did all the updates - Revit, Navisworks and Navis exporter.
One solution is to remove the coordinate models from Revit, close the model, and reopen - but that doesn't make sense - I need to see them while I work.
Message 23 of 23
MILLERJEFF2473
Lmao
