Revit 2019 Door Issue
jrobrador19
jrobrador19
Good day,
There seem to be a problem with doors. Whenever I try to put the M_Door-Passage-Single-Flush door type on a 75mm thick wall, it says that the door cannot be created.  It is weird because the door works for 76mm and 74mm thick walls.
Please help.
Jerous
Please hit the ACCEPT SOLUTION or LIKE button if my post helped you to solve your problem.
Jerous Obrador
Mechanical Engineer| LinkedIn | Autodesk Certified InstructorRevit Architecture Certified ProfessionalRevit MEP: Mechanical Certified ProfessionalRevit MEP: Electrical Certified ProfessionalInventor Certified Professional | Laguna, Philippines
Win 10 Pro / Dell G7 7590 / i7-9750H / 16GB RAM / NVIDIA GeForce RTX 2060
L.Maas
Edit the family and change the wall inside the family editor to 75 mm (consider same layers) and see if it breaks there. The family editor might give additional information on why it breaks
Louis
Please mention Revit version, especially when uploading Revit files.
Corsten.Au
Some constraints in familySome constraints in familyHi
There's a way to put constraint in the family using custom formulas and parameter to restrict
some dimension.. the shown constraint are not allowing door family or it just making sure that Frame inset
is restricted to get minimum 80mm value, lower that that wont work....something like that..
have a go and edit them..
Just for example... theres a door family, and you wanna make sure the door size is minimum 600mm,
you can put that constraint in the family so that any user who put size below 600mm doesn't allows to create that size...
hope that helps..
Best luck.
Corsten
Building Designer
