Revit 2018 Template Files AUS
When loading a generic template in Revit 2018 (Australian Localisation), it informs me it is upgrading a 2016 version.
My Revit ini file points to the correct locations, as does the Options / File Locations.
Loading via File / Open has the same results.
All files in C:\ProgramData\Autodesk\RVT 2018\Templates\Australia appear to be 2016 versions.
Files in C:\ProgramData\Autodesk\RVT 2018\Templates\Generic are 2018 versions.
Am I correct or doing something wrong!
Barry.
A_MAQ
are sure that the template file is for 2018
Autodesk Expert Elite
Yes - Definitely installed with the BDSP 2018.
B.Fetzer
often Autodesk doesn't update the deliverd Templates.
So, open the old file. After recreation (update) by Revit save it as .rte into the same folder with the same name.
While using this new file for the next project, no update is neccessary.
Kind regards,
Bernhard
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Just in case Australian set of 2018 templates under this link
c:\ProgramData\Autodesk\RVT 2018\Templates\Australia
Rafal Gaweda
Hi @Rafal.Gaweda
I get a "An invalid set of parameters has been specified in the url." error message for the link you provided.
With thanks,
Barry.
Hi @Rafal.Gaweda.
Please disregard my previous post - I had to edit the url and it is downloading as I write.
With much gratitude.
Barry.
