Revit 2018 System Tab
davidtetro
davidtetro
I just installed Revit 2018 from the Design Suite subscription I have. The Structure tab (along with the typical Revit tabs) was provided. There is not a System tab for the MEP portions of the Ribbon. I had this on the past few editions of Revit I had. Is this a bug or a bad install? Is it not offered anymore?
PijPiwo
Go to application menu -> option -> user interface, and make sure system tabs are checked (all three of them).
davidtetro
Thank you! Thank you! Thank you! If I could give more than one Kudos, I would! Much appreciated...and, then some more to a fellow beer lover!
Thank you for that! If I could buy you a beer a would 😄
what if you dont have those options ?
davidtetro
What version of Revit are you using?
I’m also having this issue. I’ve just subscribed to Revit LT 2019. Is the systems tab included in this package?
