Revit 2018 Stl exporter
arisleme
Message 1 of 11
arisleme
Is there a release date for STL exporter plugin for Revit 2018? and is there an alternative (free or paid)?
___________________________________
P.S. don't let the machine design for you!
Replies (10)
Message 2 of 11
ahto.joost
I have same question/problem too...
So far I found that there is one simple moral, to avoid problems never get the latest software version...
Is this something what Autodesk really wants?
Message 3 of 11
ennujozlagam
@arisleme  hello, not available yet at the moment. thanks
Message 4 of 11
dplumb_BWBR
I haven't found a separate download, but the STL Exporter is (supposed to be) included in the 2018 Deployment.
I say "supposed to" because there is a check box for "include STL Exporter" when building the Deployment, but I didn't see anything after I ran it.
I was able to pull the .msi out of the Deployment\Img folder under the Updates folder. Ran that by itself and it installed
Message 5 of 11
henryt
Observer
Observer
Thank you thank you thank you!
Message 6 of 11
rimacoca
Hi @arisleme
You can find the last version and news updates  in this link https://github.com/Autodesk/revit-stl-extension
A KUDO is always welcomed; However, when the above answer helps and/or clarifies your query; kindly mark this reply.
Submitted ideas
/ All Revit up dates
Projects BIM Integrated Services
Message 7 of 11
Does anyone have instructions on how to install the package from GitHub?
Thank you! Any help is appreciated
Message 8 of 11
pmichaels
After downloading STL Exporter for Revit, It does not show up in the add ins. Any suggestions? I have reinstalled and the message says it is already installed, successfully. Where is it?
Message 9 of 11
I need to understand how you did that, I need to resolve this for my high school students so they can print their homes out
Message 10 of 11
pmichaels
My tech department got involved. They downloaded a file from Github. Here
is the response from Autodesk which I used for my desktop PC:
Hi Preston,
Thank you for contacting Autodesk Product Support. My name is BJ and I am
a Support Specialist on the Autodesk Installation & Licensing Team. Your
Service Request has been escalated to me and I will be working with you to
resolve this case.
Try running the Autodesk Desktop Application to see if the STL gets listed.
If that fails you can download it from this link:
https://autodesk.box.com/s/ygjbm0jt6ifqq47shk63dn708xjzmvf2
If this solution worked and your issue is now resolved, please let me know
so I can close this support request. If the solution did not work, please
let me know the best time of day and phone number to give you a call.
When I call, if it is necessary to establish a remote session, I will ask
you to use the link below to download and run TeamViewer:
https://get.teamviewer.com/autodesk11
Best regards,
BJ Cates
Autodesk Support Team
Message 11 of 11
Thank you very much, that worked perfectly
