Revit 2018 on Windows 10 Bootcamp Print to PDF text issues (Nvidia card)
mshoffman
Message 1 of 9
mshoffman
I am having the same issue when printing my text is overlapping, doesnt matter if i pick pdf or a local printer. My option to roll back the driver is grayed out.  I've attached the journal.
Title edited for clarity by @Viveka_CD: Revit 2018 on Windows 10 Bootcamp Print to PDF text issues (Nvidia card)
Replies (8)
Message 2 of 9
mshoffman
Does this work the same for NVIDIA as i do not have an AMD card.
Message 3 of 9
mshoffman
See attached
Message 4 of 9
Viveka_CD
Hi @mshoffman
Thanks for sharing your files. I've created a separate thread for you for clarity.
Message 5 of 9
michael_coviello
Autodesk Support
Autodesk Support
Hello @mshoffman
Thank you for posting your files.
I see from your screenshots that the characters get much larger during print/print preview?
Does this happen when printing to any printer?  (Physical or PDF?)
If the problem happens with some printers, can you share the specifics of that printer?
Thank you!
Michael C
Technical Support Specialist
What's New in Revit 2023 | Autodesk University | Revit Blog
Message 6 of 9
mshoffman
Yes both printer and pdf
Message 7 of 9
Viveka_CD
Hi @mshoffman
I'm glad to hear that @michael_coviello helped with your case.
Please follow up on this thread with any updates regarding your case. This will help the community seeking similar solutions.
Message 8 of 9
mshoffman
Michael logged in and it worked fine.  I'm not sure if an update happened on my machine to fix it or if it is a display monitor issue as i have multiple monitors.  We are going to keep an eye on the issue to see if it happens again but right now it is working properly.
Message 9 of 9
Viveka_CD
Thanks for the quick update @mshoffman Smiley Happy
For now, I'll mark your response as the solution, but if anything changes, we can continue on this thread.
Do let us know if you need assistance in future.
