Revit 2018 LT-Massing
Can We do Massing in Revit 2018 LT?
I always see Mass & Site Tab from Revit in Youtube.
I don't see that on my Revit 2018 LT.
So I am wondering that I can't do massing in LT Version.
Accepted solutions (3)
paullimapa
You're posting in the AutoCAD forum.  You should post your Revit question in the Revit forum like this one:
https://forums.autodesk.com/t5/revit-architecture-forum/bd-p/133
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
pendean
Community Legend
Community Legend
REVIT LT is not REVIT, could that be the problem? Your cheaper lower version's HELP file should tell you all you need to know about what is missing while you wait.
Read this too http://blogs.rand.com/architectural/2016/09/revit-vs-revit-lt.html
loboarch
Massing tools are NOT part of Revit LT.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Viveka_CD
Hi @Anonymous
Cool profile nameSmiley Happy
What mass family are you trying to create? A toposurface?
Unfortunately, Revit LT can be used to open a Revit model with masses but NOT able to create/edit masses @ mentioned by @loboarch
See the following articles:
You can download a trial of Revit 2018, create a mass and open that in your Revit LT
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome.
Thank you,
revit 2018 kullanıyorum ancak bende de toposurface yok maalesef
Viveka_CD
Hi @Anonymous
Yığma aletleri Revit LT'nin bir parçası DEĞİLDİR
Translation: Massing tools are NOT part of Revit LT
