Revit 2018 Extensions - Freeze drawings
haydenwse
Message 1 of 67
haydenwse
It appears that the Freeze drawing command is no longer available in the 2018 Extensions.  Is there any plans to add it?
Replies (66)
Message 61 of 67
thomasarnoldsson5732
Same here. Any solutions to that?
Message 62 of 67
mahmoud_faisal2
Strange solution but it works for me
copy the files after unzipping them using 7z in these folders
C:\ProgramData\Autodesk\Revit\Addins\2018
C:\ProgramData\Autodesk\Revit\Addins\2017
even if you will not use it in 2017 version
Message 63 of 67
haydenwse
I am the original poster on this thread and have quit using freeze altogether.  I now use Images to take a snap shot of a revit detail and then put that image into legends that can be placed in my piece drawings.  The Freeze command makes very sloppy dwg files that clutter up the Revit model.
Message 64 of 67
ed.fosterEWXHU
I got it to work by using 7-zip to extract it directly to the Revit add-in folder.
Message 65 of 67
ozanridvanogluu
Community Visitor
Community Visitor
Is there never version of previously shared dll files for freeze for the latest's versions of the revit (2021 - 2022 or even 2023)?
Message 66 of 67
chauh
It just crashes 2023 upon running it.
Message 67 of 67
haydenwse
I am the OP on this thread and have found that I have no need for "freeze" or anything like it that creates large dwg line drawings that just clutter up the rvt file.  I now create "images" which look and work better and have much smaller impact on the rvt file size.  See post 57 for details.
