Revit 2018 - DWG export problem
Message 1 of 9
My DWG exports only shows partial information - in this case only the wall hatches.
I tried to Zoom extent on AutoCAD but there's no other elements within the view so I don't think it's to do with Project base point. I've unticked 'Export views on sheets and linkes as external references'.
Sheet title block doesn't get exported either. I use the exact same setting on Revit 2019 and it works fine.
Any ideas how to fix this?
Thank you in advance.
Replies (8)
Message 2 of 9
RobDraw
And those settings are?
Rob
Message 3 of 9
Hi - my export settings attached.
I followed one of the advises I found here, which was to clean up the temp files.
It worked for one export, then went back to having problems...
Message 4 of 9
RobDraw
Have you checked the view settings to see if those are the same?
Rob
Message 5 of 9
Sorry could you explain what view settings you are referring to?
Message 6 of 9
RobDraw
All of them. Look for differences.
Rob
Message 7 of 9
syman2000
Can you upload the CAD file so we can look if it is AutoCAD issue or Revit failed export. Sometimes I do encounter AutoCAD not able to display text exported from Revit. When I open the same CAD file from another computer, it shows up fine.
Message 8 of 9
Do you have any success using <in-session export setup>?  I notice you are using one called "DWG".
Message 9 of 9
Hi, I haven't tried this because our Revit manager helped me to set up this 'DWG' profile.
Interestingly, using the same profile he is able to export DWGs with no problem.
