Revit 2018 doesn't find mapped drives
I've just installed version 2018.1 however none of the file dialogue boxes (open, file locations etc) show my mapped network drives although I can navigate the long way to network locations. All my other software incIuding ACAD, 3d Max and Revit 2016 have no problems finding the drives.
I have tried the solution of running as admin off (and on) without success.
Any help would be appreciated,
Robert
Sahay_R
Go into Options. You should be able to set Places for your dialog boxes to map to.
File>>Options>>File Locations>>Places
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Just leaving a message to say the "accepted solution" above was not accepted my me, it doesn't address the problem because as I stated in my post the network drives were not appearing in the file location dialogue.
I had to uninstall and reinstall the product.
Tony_Nazaka
I have the same problem, and know what you mean [the answers dont address the problem, so I understand the frustration with them marking it "solved"]
As we have our company set up, our personal computers have a c: drive...
Then we have multiple other drives with projects, B: drive, S: drive, etc.
When I installed Revit 2018, it can only "see" the c: drive, not the other drives we have set up...
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
EnableLinkedConnections        create key or set value to 1.
Confirmed (by me) fix in 2018.
HI
AM MAJID
I TRY TO INSTALLED MY SYSTEM DISK (c) ALMOST FULL HIS NEED MORE GB THATS WHY I CANT INSTALLED IN C DISK I WANT INSTALLED IN OTHER DISK. IF YOU HAVE SOLUTION PLEASE GIVE IT ME.,..
