Revit 2018 Command Failure
Can anyone help me troubleshoot this error. Never seen this before. Trying to place a piece of furniture to the layout and keep getting this messageREVIVT ERROR.JPG
Disable or uninstall the Furniture Manager add-in maybe?
I will give that a try thanks.
Didnt' work thanks for the input.
ennujozlagam
hello, try to edit your furniture family (you downloaded this family or you created your own?), delete as much as possible information that are not necessary in the properties > edit type and see if helps. thanks
Viveka_CD
Hi @Anonymous
This error is common when the add-in is outdated.
Please see if you can run a newer version and if its compatible with Revit 2018
