Revit 2018 can't launch on restricted user
My Revit 2018 can't launch if useing restricted user, it will show the applpication close unexpectedly.
I tried to run as administrator and it works, but I can't grent the administrator's permission to this user.
Is there any solution for this issue ?? please help
ennujozlagam
hello, is that your personal computer or office computer? can you try to change your account from user to administrator? thanks
That is office PC, due to the company policy that account won't have the administrator permission.
Thanks for your advised
ennujozlagam
hello, okay..which means you cannot do anything because you are controlled by your company policy. just run revit icon as administrator. thanks
Not allowing an account to have full rights to a workstation requires a lot of tweaking.  Basically the user has to be assigned full write capability to everything under the c:\users\username directory along with the Temp and Root C.
I think there were some other folders that needed access too.
Take a look at this post for more info: https://forums.autodesk.com/t5/installation-licensing/non-administrator-accounts-can-t-launch-produc...
