Revit 2018 and Revit 2017 file compatibility and exchange
lilachshahaf
lilachshahaf
hey everybody,
i want to use outsourcing help but he is using 2017 and i use 2018/
how can i overcome this problem?
thanks in advance.
lilach
loboarch
Exporting/Importing IFC files would be the only real route but I imagine that would be less than desirable. Maybe the way to go would be to have the outsource resource subscribe to Revit or Revit LT for the length of the project? I have a feeling that would pay for itself after attempting to exchange IFC files a couple of times.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Viveka_CD
Hi @lilachshahaf
Also, see Backwards compatibility of Revit with earlier releases of the software
Upgrading Revit Projects to a New Version
You could use a trial version of the same version (2017) which your consultant has.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you,
lilachshahaf
hey
thanks for your answer.
is the revit supposed to be able to open the icf file?
do i need to open it with import or any athe special command?
Ho do you get the 2017 trial? I couldn't find it.
@Viveka_CD wrote:
Hi @lilachshahaf
Thank you,
RobDraw
Doesn't your license allow you to use the last three versions?
Rob
Viveka_CD
Hi @Anonymous
Please see this thread for more information.
