Revit 2018.2 objects - edit family
Message 1 of 9
Good morning,
I have installed the Revit 2018.2, and in the family editor, if I want to change the subcategory of an object in the identity data tab, doesn't appear the options that I have done in the object style. Someone knows some update to fix this problem?
Thanks 🙂
Patrícia
Replies (8)
Message 2 of 9
Kimtaurus
What do you mean with "options in the object style"?
If you've created subcategories and then you change the category of the family, these subcategories will be deleted as they are part the previous category.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 9
yes yes, If I change the category the subcategories will be deleted. But, my problem is when I want to change my subcategory of an object, I click in the arrow (see the image below please) and any "subcategory" appears.. it is like this button is blocked! and I have subcategories already defined.
Message 4 of 9
Kimtaurus
Can you share the family?
Message 5 of 9
I attached an example... but this happens with all families..
Message 6 of 9
Kimtaurus
It works on my Revit version, I also have R2018.2
Can you assign subcategories in other families, or is it just this family?
Try opening the family with the Autid option.
Message 7 of 9
ennujozlagam
@Anonymous hello, try to install latest graphics card driver and see if helps. thanks
Message 8 of 9
This happens with all families... I tried open with "autin" option but didn't result also... anyaway, thank you...
Message 9 of 9
Hello!! I did the updates of graphics card driver, but didnt result also.. anyway, thank you
