Revit 2018.2 - Family text different size/width than project text
fkm
Message 1 of 22
fkm
Does anyone know if Autodesk have found a solution to the issue?
Flemming
Title edited for clarity and a new thread started for @fkm
Replies (21)
Message 2 of 22
Viveka_CD
Hi @fkm
I have started a new discussion for your issue.
you wrote:
____________________________________
I have just installed Revit 2018.2 in the hope that it could solve the problem - but unfortunately not.
It means that i must go throw all my sheet familys, tags, schedule an so on in my template - if there is no solutions to this problem, ore I must wait for a 2018.3 version.
We have also skipped 2017 version in my company.
A few questions to troubleshoot your issue:
  • Do you have linked dwgs in your Revit model?
  • Is this issue with a specific font or for all fonts?
  • Which pdf printer do you use?
We require your journal files and Revit model to investigate further and reproduce this issue.
I can share a private folder if you'd like.
Looking forward to your reply update.
Message 3 of 22
fkm
Hi Viveka
Answers to your questions:
  • We do not have DWGs in our Revit Template file. The issue comes when I upgrade my Revit Template file from Revit 2016 to Revit 2018.2
  • We only use front Verdana in my company.
  • PDFCreator
If you share a private folder, I will send you my Revit Template for Revit 2016.
Regards Flemming
Message 4 of 22
rdolphins1427
Not that I know of, we have been slowly editing our families with annotation and adjusted the width slightly. Its not perfect, but you cant tell the difference until you zoom really close......Let me know if you find anything !!!1
Message 5 of 22
Viveka_CD
Hi @fkm
Thanks for getting back so quickly!
I've shared a private folder with you to upload your files. Please upload your journal, Revit 2016 and Revit 2018.2 file.
Let me know if you have trouble accessing the folder.
Message 6 of 22
fkm
Thanks, Viveka
I have uploaded Revit fil version 2016 and 2018.2 (P+P Revit 2016 and P+P Revit 2018.2).
I am not sure what you mean about Journal?
Hope you can find a solution.
Regards, Flemming.
Message 7 of 22
Viveka_CD
Hi @fkm
Thanks for sharing the files.
See here for getting your journal file, and please upload to the same folder.
Message 8 of 22
fkm
Hi again Viveka
I could not upload to the same folder.
But I have uploadet the files to folder "2017_VD Technical Cases"
My Journals are named:
P+P Revit 2016 - journal.0658
P+P Revit 2018 - journal.0018
Regards Flemming
Message 9 of 22
Viveka_CD
Hi @fkm
Thanks for getting back. Unfortunately, the journal files cannot be found in the destination folder.
I have changed the access settings. Plese try uploading the journals again and let me know if you have access.
Message 10 of 22
fkm
Hi Viveka
I have acces to the folder, but I can´t upload to the shared folder.
Regards Flemming
Message 11 of 22
Viveka_CD
Hi @fkm
Your issue is in progress.
Can you share an alternate email that I can add to the existing folder? Please try uploading your journals again.
Message 12 of 22
fkm
Hi Viveka.
I am happy to hear that my issue is in progress.
I don´t know if I am allowed, but I have created at new folder “P+P Journal” and invited you to join.
I hope you can download my journals from this folder.
Best regards
Flemming
Message 13 of 22
Viveka_CD
Hi @fkm
Thanks for uploading your journals. You may have to share the folder P+P journal - (I am unable to download or preview them)
The journals will go a long way in investigating the issue.
I will let you know if we require any other information. I may share a collector utility if required and follow up with an update.
Message 14 of 22
fkm
Hi Viveka
You have now full acces to the folder P+P Journal.
Please let me know when you find at solution.
Regards Flemming
Message 15 of 22
Viveka_CD
Thank you @fkm
I am able to download your journals now.
I'll follow up with an update.
Message 16 of 22
Viveka_CD
Hi @fkm
Few more questions- does your family text 'overlap' or 'shrink'
Is this behavior only with Verdana font? Have you noticed the same behaviour with any othe font?
Did you try any other PDF printer?
Message 17 of 22
fkm
Hi Viveka
The text becomes wider and higher.
I have just tested font Times New Roman, and it behavior the same way as Verdana. The text gets wider and higher.
I have not tried another PDF printer. The problem is in Revit. When I print, I print the layout from Revit. I don't think this is the problem.
Regards Flemming
Message 18 of 22
fkm
Hi Viveka
Just to clarify - the problem is both in family text and project text. The text gets wider og higher.
I have just read the Subject text again.
Regards Flemming
Message 19 of 22
fkm,
I seemed to have solved our issue, I'm not sure if this will solve yours.
I saw on another post that it might be an issue with Windows and not Revit. I logged in as myself on the computer with the problem and everything prints as expected. I then logged back in as the user that is having the problem and it went back to the wide text on the PDFs.
I adjusted the font size under the display settings to 101% for that user and 'poof' like magic everything prints fine.
Hopefully this helps
- Tom
Message 20 of 22
Viveka_CD
Hi @fkm
After investigating all your files, I'm sharing an update from the dedicated resource team at Autodesk which works closely with the Revit's test engine:
This issue is seen in cases where the font wrapping changes when editing various zoom levels, etc
The new text component in Revit 2018 renders text slightly differently and results in some fonts getting slightly wider and some fonts getting slightly narrower.  This is often not noticeable, but in cases where a line of text in very very close to wrapping, the slightly wider font might cause a wrap–which is what has happened in few instances.
To fix it you, can either stretch the box of the text note (or label) slightly to accommodate this and not wrap.  Or you can make the text slightly smaller.  In the latter case, you can change the Verdana text from 3.000 mm to 2.970 mm and the wrap is quelled.
Changing the font scale/ resolution to 101% is a temporary solution. This may not apply if you have multiple monitor setup.
Let me know if this helps.
