revit 2018.2 dimension problem
Message 1 of 9
Hey . After updating to 2018.2 there was a problem with the sizes. that is, it is impossible to set the size in the desired position (only short ones, those that do not take to the extension lines). Tell me what could be the problem ??
Replies (8)
Message 2 of 9
-FDC-
Post your drawing so I can check it.
Message 3 of 9
yes. here file  / thank you
Message 4 of 9
MostafaElashmawy
I checked the file and it's working probably at my side on Revit 20.18.2
I think may be a clean uninstall then install of Revit would help
Mostafa Elashmawy
Message 5 of 9
-FDC-
Working fine over here!
I did notice though that you are using another font.
This font is substituted (changed) to something else when I open the drawing.
Nothing was filled in at text font when I open your drawing and try to edit your dimension style (see screenshot).
Probably because I don't have your font.
My guess is that you are using a "bad" font.
Test it by changing the font of your dimension style to Arial.
Message 6 of 9
Thanks for help, but after changing font the same problem / i will try to reinstall revit
Message 7 of 9
-FDC-
If you want I can save it with my Revit version and mail it back to you.
Message 8 of 9
cbcarch
Does this help?
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 9 of 9
There worked modplus plugin, problem is closed
