Revit 2017 Text editor bug (not the resizing issue, apart from that)
Message 1 of 23
I discovered some weird bug in the new text editor. After upgrading the project from 2016. When I create new text within a viewport that’s on a sheet. The text selector stays on the left while typing – making it impossible to select text and edit/erase. when i move my type selector with my keyboard arrows, the left arrow moves the selector to the right and the right arrow moves it to the left, BUT! when typing the actual typing doesn’t start where the selector is, instead it follows the real directions of my keyboard arrows – making it impossible to know where you are editing/typing.
When I edit/create text directly in the views they work fine.
Replies (22)
Message 2 of 23
SteveKStafford
That sounds like the mirroring issue that support is working on a fix for now. My understanding is closing the view and opening it again will help restore normal behavior, until it happens again. What about when you aren't working on the view via the sheet, which is what it sounds like you were doing?
Steve Stafford
Message 3 of 23
Yes, it works when editing directly in views only.
Message 4 of 23
Btw is Autodesk working on a fix for this font size conversion ratios with the new text editor? The issue is not just upgrading well developed projects from 2016 with lots of text but all the families, details, etc.
I can't imagine that big firms that has spent years perfecting their families, details, etc. should just be fine with that?
I see this is a major problem everyone is having and has huge implications for BIM management.
Message 5 of 23
GLDevco
I continue to have this problem regardless of the type of view, upgraded/new project, or anything else.  Its in all text editing situations.  Is my situation unique?
Message 6 of 23
Hi
I have this problem on one view but not on others.  Is there a fix out yet?
My workaround for now is to type out the test on a view where it works and then paste it to the view where I need it. Lets hope the first update fixes it
Message 7 of 23
Do you know if this fix will be and part of the R1 release or a separate independent release - meaning they release it as soon they fixed it?
This bug is a huge problem working on legends/specifications with lots of text. Super frustrating.
Message 8 of 23
This was happening to me every time I used text - it never occurred to me it had to do with working on the view via a sheet. Thanks for the temporary fix, it was driving me crazy!
Message 9 of 23
My observation is that the SP1 has not fixed this problem 😞
Please can we have a Hotfix...please,please,please
Message 10 of 23
cmilton
I have found the same. SP1 has not fixed this issue.
This NEEDS to be resolved ASAP!
Message 11 of 23
archit3374
I too have had all of these problems and I have honestly felt that this Text Editor upgrade has been a big fail and not worth it.
Message 12 of 23
Is it weird that I don't have any of the problems you guys are having?
Message 13 of 23
archit3374
If I create a new text box then try to go back and edit it, 75% of the time I have to just start a new text note because the cursor never winds up deleting the proper text or inserting it in the proper place. Ex. Just yesterday, I clicked at the end of a note I had just created to add in more text and and even though the cursor was at the end it was adding the new text just in the middle of another word. I tried it 5 times before I created it all over.
Thank You,
Keith J. Martelli
Martelli Architects, LLC.
94 Farnsleigh Avenue
Bluffton, SC 29910
Ph. 843-757-5776
Cell 732-757-5779
Fax 732-508-8943
Note: The information contained in this message may be privileged and confidential and protected from disclosure. If the reader of this message is not the intended recipient, or an employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us immediately by replying to the message and deleting it from your computer. In closing, we thank you for your consideration.
Message 14 of 23
This is the mirroring issue that Autodesk knows about. Have you tried the service pack update? Apparently they have fixed it already.
I haven't gotten that issue again, but some people say they still experience the issue after update. Try it and see what happens
Message 15 of 23
So far, the main problem that I am encountering is the text size difference between 2017 and earlier versions. 2017 text are generally larger so I need to watch out for text jumping off views and sheets. Another one is the lagging inside editing window.
I can live with those to welcome the 2017 improvements: case switching, space between paragraphs, different levels of numbering in one block of text, to name a few.
Message 16 of 23
What I did was change each of my text types (i.e. 2.5mm, 3.5mm 5mm, etc) go into the type properties and change the width factor from 1.0 to 0.95. This seems to keep all existing text from upgraded models within their text box spacing, so no need to readjust everything after that. That is if the font was Arial. For other fonts the width factor might be different.
Message 17 of 23
archit3374
I have not updated yet, I will do that
Thank You,
Keith J. Martelli
Bluffton, SC 29910
Ph. 843-757-5776
Cell 732-757-5779
Fax 732-508-8943
Message 18 of 23
One more thing I just noticed is that the new font size change is not implemented though out the entire program. For example, the size of the label in a View Title family while set to be exactly the same as a Text type in Project, but when loaded in the Project, it is visibly smaller than an identical piece of Text.
Edited:  Same thing happens to schedule text.  Same text type for Text Note and Schedule, vastly different sizes on drawings.  I started getting angry.
Message 19 of 23
Hi
I've also noticed a difference in text size between text and tags.  My assumption is that labels are still sized according the the old method.
Message 20 of 23
Hi cmilton
Have you seen SP2 is out?  I'm holding thumbs it solves this problem for the guys where SP1 didn't help 🙂
