Revit 2017 no Libraries installed
Hi Recently installed Revit 2017 and it says is on Viewer mode Built: 20160225_151(x64)
I don't have any libraries on my software and it never asked me to activate license when I did the installation.
I don't understand a great deal about this stuff and I don't know if I have to install again and if I do how many times can I install the same product again in the same computer?!
how can I solve this problem I cant use the software properly I don't know what to do?1
cheers
rendermaster
check discussion/post here:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
and here:
http://forums.autodesk.com/t5/revit-architecture/installation-of-revit-2017-content-libraries/td-p/6...
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
jitu1dange
I would suggest you do a clean install again. This time you use Virtual Agent to download the software which includes Material Library and components. Before installation turn off your windows fireawall and anti-virus program.
http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
I hope this helps 🙂
jitu1dange
Link to Virtual Agent: http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
1. Download Links
2. Select Revit Products.
3. Select Autodesk Revit
4. Under that you can find links to all available versions.
I'm having the exact same issue as mtsal3. I have totally uninstalled and reinstalled Revit, the content libraries, the service packs, etc, multiple times, including deleting temp files, and trying both in a single installation, and in a series of individual installation. I have downloaded the two-part Revit installation package using the Virtual Agent, which does seem to eliminate the error message about content libraries not being downloaded, but even then, after I select the libraries (US Imperial, US Metric and Canada, either individually or together), the installation gets through most of its work, and then hangs while the content libraries are being installed. I've been trying everything suggested on this and other forums for the last 3 days and I'm at a total loss. What do I try next?
Did you solve your issue, mtsal3?
Update: I've solved my problem. In the end, I found that the content libraries were, in fact, installed (even though they seemed to hang every time and the computer was reset at that point) but that the locations had not been updated in Revit/options.
For others' reference, here is the thread that helped, in my case: http://forums.autodesk.com/t5/forums/forumtopicprintpage/board-id/24/message-id/133894/print-single-...
Cheers.
