Revit 2017 Material Path
Hi why am I unable to edit wall materials with revit 2017 when I can with revit2016 by checking the box with 3 dots
Ahhh, the old "3-dot" problem. Which "3-dot" doesn't work for you?
Troubleshooting Tip #1: Verify a problem actually exists.
Do all the "3-dots" not work? If so, this is a cool, new problem to me. When you're back on-line, let me know.
provide a print screen shot so we can exactly figure the problem. 🙂
Hi I have no problem in editing wall materials with rivet 2016 but with rivet 2017 I am unable to edit the materials. when I click on the ... symbol. There is no response, If I type in a description I am unable to change materials
Thanks Peter
Sent from Outlook
Strange, Peter. Have you tried a reboot?
hi still trying
